1 - 12 of 12 Posts
Hey guys, I have a 2001 Canadian version Odyssey that has a keyhole shaped slot on the top of my steering wheel (between horn/airbag cover and dash). What is it for??
It is used to manually unlock the steering wheel. if it won't turn.
You remove that cover and insert your key (or similar shaped item) and it will manually unlock the steering wheel so you can turn the front wheesl.
Why? In case the solenoid that unlocks the steering wheel when you turn the key to ON and press on the brake pedal doesn't unlock it, or, perhaps the battery is dead and you need to move the CRV and you need to turn the steering wheel, etc.
Buffalo4
Discussion Starter #4
Buffalo4
Ahh! I had thought, perhaps maybe? But it seemed rather odd as opposed to the old wiggle the wheel trick to unlock, on every other vehicle I have ever owned. Thanks!
I was mistaken on what that slot was for,overall. It is actually the shift lock release slot cover on the steering column so that you can shift out of Park and into any gear, Handy if the battery is dead, etc and/or if you need to move the vehicle and you can't take it out of Park (if that wiggling the wheel trick doesn't work).
Page #162 in the 2000 Owner's manual under Automatic Transmission.
Sorry.
Buffalo4
No, you were correct that the slot is used when the normal shift unlock mechanism is inoperative e.g. solenoid, battery, etc.
The wiggle is used when the unlock mechanism is working okay, but the steering wheel has too much tension on the unlock mechanism. (Driver shifted to P without releasing the steering wheel first.)
A third scenario is when the unlock mechanism is working okay, the steering wheel is free, and still the shift lever cannot be moved because the weight of the car is resting on the transmission parking pawl. (Driver didn't apply the parking brake on a grade before shifting to P.) The solution is a hard pull on the shift lever.
Discussion Starter #8
Sorry.
Buffalo4
No worries mate!
Discussion Starter #9
Aha!
Aha! For instance, when I park on a hill and forget to set the e-brake...the shift is hard out of Park. Thanks!
Try to get in the habit of parking like this always:
Come to a stop, shift to N
Set parking brake
Remove foot from brake and let the van come to rest on the parking brake
Put your foot back on the brake and shift to P
It will come out of park like butter.
Honda automatics are not like any other. They are just not like a typical American car.
Here is another way they are different: when shifting to D after backing out, always come to a complete stop and then, after shifting to D, wait a beat before proceeding. That jerk from not waiting is doing damage. A little bit, every time.
...when shifting to D after backing out, always come to a complete stop...
This is a practice that was common when most cars were domestics, and has no doubt continued to the present. The transmission is forced to work as a brake. Yeah, it definitely wears on the transmission.
...after shifting to D, wait a beat before proceeding. That jerk from not waiting is doing damage. A little bit, every time.
This is definitely a quirk of the Honda automatic. Hitting the gas before the gear has fully engaged is the same as dropping it into gear with the engine revving. Yeah, it's very tough on the transmission.
If you lose power - such as dead battery - you can unlock the steering wheel and steer the car.
1 - 12 of 12 Posts
