I have searched all the threads I can find but none covered this scenario.
I popped out my moonroof switch to change a dead bulb (I learned about this from here TY all) after I did that ALL my dash LED's went out. The window switches on doors still light up but none of the others. A/C, Radio, Slider door openers, etc. I tried to replace the new bulb with the old one I removed but no help, still out. I did not remove any wires, just in case I checked the switch to make sure it was not loose. It is fine and the switches themselves work fine. I noticed that with headlamps on the Green A/C light flickers now as does the orange recirculate light on A/C panel. Headlamps off no flicker.
All fuses check out, no smell of burning or smoke from a short was witnessed.
Anyone have an answer before I am forced to pay my mechanic (who is fair and honest but wont work for free. LOL) to find the problem. I do not believe it is a case of massive bulb failure all at once. The bulb I changed was out when I bought the van last year and I finally decided to change it. The flickering indicator lights on A/C panel has me worried about a bad connection somewhere, not a bulb problem.
TIA,
David
maybe you should check for a blown fuse or possibly bad ground?
Fuses are all OK
We are trying to test all we can to find the connection problem. Something is amiss, but what? The search continues on Tuesday.
get a fuse tester - I know how hard they are to check FIRST HAND - and I bet you missed one... not that I think you're blind, but there are so many fuses in such a small area at such a tough angle - you know what i mean...
It turned out that when I popped out the moonroof switch I disconnected a connection deep inside the dash due to a "too tight" bundle. We had to remove all kinds of trim and look for quite a while before we found it. 1.5 hours labor and $100 later I have all my lights again. I was sooooo careful when removing the switch not to do exactly what I did. We tightened all connections and loosened the overall wires so as to not happen again. I imagine this is the same reason so may here have said they did the old "bang the dashboard with a fist" repair. Loose wires too tightly wound in a bundle lead to disconnects.
