Location of MES plug for 1996 Honda Odyssey to reset srs light.
Every thing I read says it is located at fuse box.
But I have a dummy yellow receptacle located about 18 inches above the brake pedal and attached to a crossbeam. The plug to it is yellow and has two grey wires inside the yellow sheath. Then they run to a yellow sheathed wire that connects to lower front of fuse block. I am almost sure the mes wire is the one plugged into the dummy. But I sure don't want to to trigger the seat belts if it isn't. HELP!!
