Anyone had any luck/reason to source new wheel studs for their van? I am trying to fit 16" BBS wheels to my 2006 - learning there are a whole lot of measurements in non-stock wheel sizes. These BBS wheels are originally from a 3-series BMW and they *almost* fit, except the wheel studs are just a bit too short.
I've searched all over the internet and the local racing shops, no luck yet. Honda dealership was also not helpful - they can supply the standard studs, but not longer studs.
Specs are 16.5mm knurl diameter, 51mm long and 14M thread pattern - I need at least 60mm in length and similar thread (will replace lug nuts if necessary).
Any experience in this? Any idea where I can get the studs that fit? They seem to be quite unique (along with the bolt pattern).
On the upside, no problem removing the studs - just needed to remove the caliper and brake disk; they just slide out the back.
Thanks, Steve.
Thanks, Steve.
