1 - 2 of 2 Posts
hello. I was trying to install my car alarm on my 2014 odyssey but I couldn't find out the negative door lock wire. I tried all wires tested by a circuit tester but can not find it. someone who knows what is the negative or positive door lock wire? ( I found one of the wire. when I put tester on the wire and door open or close button same time, the tester is blinking. I think this is not a positive wire, isn't it?
instruction said - lock 250mA negative (-) output. the output can be used to trigger the lock wire on the vehicle. This output can also be used to trigger a relay if you need a positive (+) lock output. This wire can also be programmed through special option group $2 as of 19 different outputs.
156456
156457
156458
156459
1 - 2 of 2 Posts
