I have a 2002 Odyssey that has a loud noise on the Passenger side. It's a loud roar, it's not the antenna. It will go away if I put the window down a short way but then the road noise comes in. Ive cleaned all door seals both front and back,shut all vents and tried every control too see if it made any change, it didn't. No rack on top. Noise come in any where from 40 to 70 miles an hour, maybe side winds seem to make it louder.:frown:
Search on the terms: "windshield moulding noise" or "wheel bearings" (which if they are faulty - I don't understand the noise going away with the window down)
I have that as well.. But the divorce lawyer said it would be cheaper to live with it. :rollingeyes:
What type of noise is it? Is it variable or a constant sound?
I 2nd wheel bearings, or possibly a tire issue (had this before on an older set of Michelins). It may transfer to the cabin better when the window is up, when the window is down it might be covered by the sound of the wind/air coming in the window.
