1 - 6 of 6 Posts
I have an -01 Odyssey EX with about 145k mi. This afternoon when I put the car in reverse I heard a loud screeching noise and several of the panel lights turned on (the battery light, the lights indicating the opening of the doors, and Brake light). After a few minutes, I discovered that the loud screeching noise would come on every time I turned the AC/Heat on. When I turned the AC/Heat off the screeching would go away. The panel lights remained on, but they would flicker off every 30 seconds or so but would only be off for a maximum of 5 seconds. The van seemed to be driving just fine although there was a slight, occasional tapping/clicking noise. On my drive home, the panel lighting got dimmer and dimmer, eventually the radio shut off, the odometer went blank, and additional panel lights turned on (TCS and another one). When I got off the freeway, I noticed that my front headlights were very dim. Fortunately, my kids and I made it home. I turned the car on and tried to start it again, but it was completely dead. Again, the car seemed to be driving just fine, except the longer I drove the less power I had.
Does anybody have any input or suggestions? I just officially joined this group but have followed it for the past 3 years and it has been very helpful for me. Thanks.
Your alternator and AC compressor are driven by the same serpentine belt.
It sounds like when you load it up (by switching on climate control, hence AC), the belt is badly slipping on the AC compressor pulley. Is the compressor frozen, thus wrecking the belt?
As well, it sounds like the alternator pulley either is not gaining enough purchase on the belt (thus not charging the battery), or the alternator is on its way out...
...just guessing.
x2 -- I would suspect that the ac compressor gave up on you and the alt is on its way out too. but thats just a guess. with the car off and cool I would grab the ac compressor clutch and try to turn it by hand. if it wont move the compressor is locked up, and the alt can be checked at any advance auto parts, autozone, orielly's auto, etc they do that for free.
Thanks for the comments. This morning the van turned on just fine. What I believe is the serpentine belt (it's not the vertical one, but the other belt underneath that is horizontal) was not moving whether I had the AC on or off. A few minutes later, the horizontal belt started to move but every other second you could hear a quick click sound. At that point the lights started to dim and moments later the car shut off.
...the serpentine belt (it's not the vertical one, but the other belt underneath that is horizontal) was not moving whether I had the AC on or off. A few minutes later, the horizontal belt started to move but every other second you could hear a quick click sound. At that point the lights started to dim and moments later the car shut off.
mb, the thinner belt that oriented vertically is for the power steering belt.
Are you saying that the wider belt is not moving while the motor is running, then eventually starts to move?
1 - 6 of 6 Posts
