Center Pocket Light Replacement
1. Remove the center pocket (Remove the 2 clips and detach the 3 clips and tabs, then remove the center lower trim - the part with the ACC socket/Remove the center lower pocket - 1 Remove the 6 screws/2 Gently pull out along the top of the center lower pocket to release the clips/3 Disconnect the center lower pocket light connector)
2. Disconnect the 2P connector from the center pocket
light.
3. Check for continuity between the No. 1 and No. 2
terminals.
• With the button (A) pressed, there should be no
continuity.
• With the button (A) released, there should be
continuity.
4. If the continuity is not as specified, check the bulb,
if the bulb is OK, replace the light.
