1 - 1 of 1 Posts
The passenger side manual sliding door on my 2001 LX is difficult to close. It almost appears to be rubbing. If you pull the door away from the vehicle at the rear side it closes fine. It appears that spring on the sliding guide is not strong enough to hold the door in the correct position while it is sliding closed. Any other with the problem and correction?
1 - 1 of 1 Posts
