In my 2011 Odyssey EX-L, map light stopped working all of sudden (both bulbs). It would not work either with doors or switch.
Removed the lens and inspected the blubs....which were fine. If I push on the bulbs, it would work but as soon as I remove the pressure it stops working.
Removed 4 screws securing the assembly and pulled out the lights fixture. Tested continuity at the switches....switches were working fine.
Then I noticed that one of the terminal to bulb is a direct connect to the switch (middle pin out of 3). As we push the switch on/off, that terminal would move. On further inspection I saw that the terminal has become loose over years of use.
Removed the switch by pushing it out, pull out the metal connector (rail) and crimped the terminal a bit using nose pliers. Put everything back, voila its working again.
I am using Sylvania DE3175 10W bulbs without a problem for over 2 yrs....no need to buy expensive Honda 8W bulb in my opinion.
