1 - 9 of 9 Posts
I need help I am getting misfire codes on PO302, PO304 PO305, P1399 I have switched coils put in spark plugs Did a compression check all right around 180PSI and seem like Cylinder #2 is the faulty one even after switching coils and changing spark plugs While running i have discconected coil in cyl 2 and doesnt affect the engine rpms like the other coils do
Thanks in advance
George
Use OEM NGK Platinum spark plugs. Most cases this is a faulty coil(s). To a lesser degree it could be a faulty injector or a loose/bad electrical connector.
The P1399 code is a temporary code related to the cylinder misfiring codes P0301 to P0306.
Discussion Starter · #3 · (Edited)
misfires
i thought i took care of the bad coil by switching and i did put in nkg OEM spark plugs gapped at .044 the wires to coil all get battery voltage when key is on. Also wouldnt a faulty injector cause a injector code to be included with the misfires? a P0171 or something like that?
P0171 would be a problem with the fuel pump, fuel line, fuel filter, fuel pressure regulator, O2 sensor or EVAP Cannister Purge Valve.
You don't have any other codes than the ones mentioned, right?
I am attaching the troubleshooting for your codes if that helps but 9 times out of 10 it is a bad coil.
2011 Odyssey LX, 120k miles
Thanks in advance
George
An ignition misfire on one cylinder could cause all those codes, so don't assume that it must be a problem beyond #2.
Swapping coils like you did seems to eliminate them as the problem (of course, assuming the problem stayed on #2).
Swapping or replacing plugs as you did seems to eliminate them as the problem.
If you're concerned about the injector, you could use a "noid light" to see if the injector is getting the appropriate signal to fire, but that is not especially easy to get to (the connector to the injector).
I had a P1399 code (I don't think I had any others) and rough running earlier this year. I could not isolate it to one cylinder like you have, took lots of stuff apart, replaced fuel injectors, cleaned + re-torqued intake manifold gasket, and finally fixed it. I don't know for sure since I did so many things, but I think it was the intake manifold gasket and corresponding surfaces.
thanks for the misfire codes and procedures Ill get started tomorrow thanks again:) I really wish it was a bad coil;(
make life easier:!
George
It's a bad coil.
Don't bother swapping them.
Just unplug the electrical connector one at a time to each plug.
THE ONE THAT HAS NO CHANGE is the BAD one.
Good ones will all drop RPM when unplugged.
A bad one will show NO change when unplugged!
Go to Adv. Auto and get part E745.... $49.00
Replace it and your van will run fine.
10 minute job.
Second retiredodyssey suggestion but I got two coils, one to replace the bad one and one to put in the glovebox as insurance that I won't have another one go bad... but just in case.
It's a bad coil.
10 minute job.
Go here for youtube fix
1 - 9 of 9 Posts
