Ugh, by the time I get done with this van, I will have replaced everything new.
Here is list of my many issues:
Odometer does not work
Trip meter does not work
Check engine light does not work
Dome light do not work
weird noise at start up, sounds like a fuel pump priming, but its loud and under the hood
srs light on
abs light on
any ideas ?
thanks....
a couple of ideas;
-pop the cover off the dome light and check the bulb. Also check if there's a ground wire up there that might be loose
- search around on here regarding ABS light and codes. you can pull the code using a paperclip. In my case, our van has a bad rear left sensor which I hope to replace soon
-SRS light - again, search can be useful. I forget how to get codes but this one has been covered.
- Buzzing underhood might be the ABS unit. I don't recall what it's doing when it does that but I know from checking around on here that it's normal.
Hope that helps,
Greg
Thanks for the info - I have replaced the bulbs, both the front and back. No go. I will check for the ground wire today and see what I can find. I read the thread on the ABS Accumulator. Sounds Expensive :-( . Luckily I love junk yards, and I have tools. Right now the SRS has higher priority.
Thanks Horatio
