1 - 2 of 2 Posts
I'm still considing a long towing trip and thinking about how I could monitor the transmission and give it a rest if it is getting stressed.
Monitoring temperature is about all I can think of. Are there others? How hot is too hot? Is there a DTC I can read that will give me tranny temp or should I put a sensor on the cooler line?
Pretty simple way to keep your transmission going strong. Don't push it past 3k rpms.
Edit, you are towing, do the same as above but also install a transmission cooler 20,000 GVRW should do the trick.
1 - 2 of 2 Posts
