I mounted the tire behind the second-row left side seat.
1. I Got a tire mount from a 1997 Honda CR-V.
2. Drilled 3 holes in the side plastic panel. To mount it I used 3 -2" washers for strength.
3. To get to 2 of the studs I removed the speaker. For the third stud bottom right I cut a 2"x3" hole to the right of the stud for access. The fourth right top stud I drilled a hole 1/2" below the storage top and used a bolt(same size of stud) with a nut threaded a bit on the stud and tightened the bolt into the nut to secure.
Pic's added below in new reply.
