If anyone's interested I'll be posting photos of our 99 Odyssey with 17" OEM wheels off an Acura CL-S. They're 17x7, 114.3mmx5 bolt pattern, 55mm offset. Tires are 235/55-17. Stock wheels of the Odyssey are 16x6.5, same bolt pattern, 50mm offset.
Accounting for the new offset, wheel width, and tire width the new tires will be .20" wider on the outboard side and .60" wider on the inboard side than stock.
The new wheels alone will stick out .05" inches on the outboard side and will stick in .50" inches more than stock on the inboard side.
I was told by tirerack that 235 tires will fit the Odyssey just fine so I have no worries. I can feel about a 1" gap between the current stock tire and the nearest suspension component. So with the new setup I should have .40 inches gap remaining.
I was hoping to get 225 size tires as this would lower the over profile of the tires but the only choice I've found in this size was a Continental - yuck. I've heard good things about the Dunlop SP A2.
If this setup doesn't work I'll post it.
