I am partial to buying/using USED Thule feet and crossbars. I would recommend a set of Thule 450 Crossroads with 60 inch square bars (old school), or a set of the Thule 450R Rapid Crossroads and a pair of Thule Aeroblades ARB60 or Thule Squarebar evos (150 cm) or even Wing Bar EVOs (150 cm). The squarebars slide through the 450 crossroads, whereas the top part of the 450R rapid crossroads slide in the slots on the underside of the Aeroblades, wingbar evos, or Squarebar evos. Both crossroad versions have a rubber coated stainless steel strap that wraps under the side rails and holds the feet snugly.
The 450 crossroads were discontinued a few years ago, but the 450R rapid cross roads are still current stock. All of these can be found 2nd hand for much less than retail on Craigslist, eBay, as well as Facebook marketplace, or occasionally at thrift stores.
I removed the OEM crossbars when I bought our van so I could have more flexibility in crossbar position/spacing depending on what I am carrying.
Yakima also makes great products—over the years they have had many different feet that would attach to raised side rails. Yakima also has a few different crossbars which use various mounting adapters.
Frankly, I found that the choice between Yakima and Thule products was similar to choosing between Toyotas and Hondas. It was harder to figure out the different trim lines/options/packages of Toyotas/Yakima than Hondas/Thule products.
Am sure that others in the forum will have their suggestions/experiences with other brands as well.
