1 - 8 of 8 Posts
My 2000 Odyssey Brake light switch is on and the driver's side brake lamp does'nt was work. Passenger light functions and third middle light works. All the running lights also function. Could it be the sensor? Any suggestions?
That tells you the bulb is blown, have you replaced the left bulb? If you have there is another electrical issue like a shorted wire or something else.
I have tried replacing it with the correct replacement bulb but that did not solve the problem. The driver's side brake light will not work.
The bulb is a dual-filament bulb #7443 and is the bulb on top.
There is a brake light sensor in the rear that can go bad if the bulb is not the answer.
See the attached diagrams...
1 - 8 of 8 Posts
