21 - 40 of 542 Posts
Discussion Starter #21
You're welcome, I'm trying to update the 1st post....(can't find the edit button)
I brought most Parts online, due to saving cost $$ , driving around, no-tax & free shippings, and only had time to play with Odyssey on Part-weekend.
What parts u plan to get?
nomorenow,
Thanks for your list, I have purchased 2012 LX and looking to buy these parts, can you tell me from where you have purchased these parts store/website?
I am looking at handa.com, if I can get better price it is good.
Thanks
Discussion Starter #22
Kenwood KOS-A300 Factory Radio Upgrade System
IMG_1234.jpg Got this Crutchfield $49, was $269.... IMG_1238.jpg Removing parts..... IMG_1239.jpg Removed heater controls.... IMG_1244.jpg Showing the actual size, bigger than I thought (skipped, had to find good location for it)....... IMG_1245.jpg Mean while, I drilled-thru the pen holder above the Stereo deck..... IMG_1247.jpg Tapping on to the factory harness...... IMG_1249.jpg Starting putting back together to test it out....... IMG_1251.jpg Hmm....found a good place for Kenwood unit, front Passenger-side behind glove box.
Discussion Starter #23
Kenwood KOS-A300 Factory Radio Upgrade System Part 2
IMG_1253.jpg Connected, all works!!!.... IMG_1256.jpg Mounted & strapped down..... IMG_1258.jpg Put back Heater control.... IMG_1259.jpg Drilled-thru and used Valcro Fasteners to 8GB USB drive $8 bucks, rather than an iPod if get stolen $$$$. IMG_1261.jpg All put back together, and ready to rock!!!... IMG_1262.jpg Showing the song info's.....
IMG_1263.jpg And comes Mulit-Colors (Colors can be sync OR no with Knob control colors. Up to the user).....
IMG_1267.jpg Final, matching with OEM display above, while the Knob controller constant slowly changing colors.....
Total install time: about 3hrs
Discussion Starter #25
Thanks~!!....extra money sound good.
Like I said, this is my 1st new car.....I was never an Installer (bit a learner), I just like take things apart as a hobby.
My co-workers call me crazy already for taken aparts......LOL!
YOU'RE THE MAN!!!! :)
you can make money in doing this install!! :0 just saying..
I am looking for OEM exterior fittings and looking for a GPS with backup monitor. non OEM products for interior (they can be replaced after using for a while).
Can you tell me which LED lights you have used for interior lighting?
Thanks
Discussion Starter #27
Thanks
For the OEM fittings:
Splash guard, Body molding are coming from Ebay, since they lowest prices I can find.
The LED's:
The front Map light & trunk they are 31mm Festoon 5050 SMD w/ 12 leds, you need three (3)
The interior & doors use 194, 168, 501, T10, (<<<---all the same, just different #'s) 5050 SMD w/4 Led's, Don't get the 5-leds(too long).
About the GPS & Backup Camera & monitor......sneak preview of coming up projects. Item's just arrived.....
IMG_1270.jpg $155.Ebay All-In-One.....7" mirror & 5" monitor w/ GPS, AV-In(backup cam), Bluetooth, HD DVR, FM transmitter, WINCE 6.0
You can also can get without the DRV & smaller 4inch screen about $105.
IMG_1271.jpg Real life size, pretty long.....
IMG_1298.jpg those two will be working together wireless (module not shown)......1/3" Sony CCD backup camera w/reference line $30 Ebay
IMG_1274.jpg Here the menu....Windows CE 6.0
IMG_1276.jpg It comes with preinstalled iGO 8 GPS.....
IMG_1295.jpg Preview from inside the van......the DVR auto-record when engine on....also can do both GPS & DVR same time (tested)
IMG_1301.jpg coming project "Optimum Opti-Coat 2.0" awaiting for a good weather to do it. $60 Ebay
IMG_1302.jpg coming project " Pre-cut Clear bra - full set" will applies after Opti-Coat 2.0 $60 Ebay
IMG_1299.jpg coming project " 15mm Chrome trim strip" after Opit-Coat 2.0, this for door-handles, wheel base fenders. $15 Ebay for 26ft (8m)
Hi,
I am thinking to buy weathertech floor liner for 1st row and mats for 2 & 3. Is this a good move?
I have read on this forum, if we add liner for 2 & 3rd rows, it is hard to get into the boxes down there. Is it true?
Thanks
Discussion Starter #30
The Weathertech are great too!, But I went with OEM because it comes with all three rows.
The spare tire are in the 2nd row (Honda called "lazy susan" hidden box"). Yes, I have to remove the rubber mat if I need to use the spare tire.
About the GPS, is china brand "Lson" but is not label and is china Patented behide the GPS unit.
Hi,
Thanks
Any upgraded rims yet?
Discussion Starter #32
not yet, I did look into it (tirerack.com).....it wouldn't be cheap $$$~!. So the rims will be my last to-do list for now.
Discussion Starter #34 (Edited)
Thanks McGinn~!!, I would said 65% is for looks & 35% from the inside. These Led's only produce a dim light in front without the headlight on.
I have read other fourms (ex:lexus,bmw) that you can get a driving ticket with foglight being On. These LED's are 5-watts vs 50-watts (oem, or high powered LED's) When I have mine HID turn-on @ night. The HID over powers the foglight (DRL) so less risk for getting pull-over for it.
nice work, do those foglights make a difference from inside, or more for the looks?
Discussion Starter #35
Multi-GPS-Backup monitor Rearview Mirror
This week I finally install all three units (GPS Mirror, Sony Backup cam, & the 2.4ghz Transmitters) working together......
IMG_1272.jpg GPS DVR Mirror arrived..
IMG_1274.jpg The unit use Windows CE 6.0 to run the GPS software.
IMG_1295.jpg The unit doesn't look big once mounted cuz the huge windows of the Odyssey.
IMG_1298.jpg Here the pair unit.
IMG_1312.jpg Upclose of the SONY CCD backcamera with Guidelines (Green, Yellow , Red Lines).
IMG_1314.jpg Here unscrewing the backup camera.....
IMG_1318.jpg This camera was design to fit 2005 to 2010 Odyssey (see part 2)
IMG_1350.jpg The 2.4ghz wireless transmitter arrived one week later
IMG_1351.jpg This is simple unit to easy install.
Discussion Starter #36
Part 2 - Multi-GPS-Backup monitor Rearview Mirror
IMG_1360.jpg 1st removed 4 screws from overhead console.
IMG_1361.jpg The last two screws is behind the LED bulbs.
IMG_1363.jpg Inserted the 2.4ghz Receiver unit as shown.
IMG_1367.jpg There already a hole in front of the console, push thru the USB (power) & 2.5mm (video feed) then we're done!!
IMG_1369.jpg This how is look like with the Tail Chrome piece removed.
IMG_1373.jpg Pre-testing , ensure the backup camera are not defective.
IMG_1461.jpg Use some hot glue to secure in place.
IMG_1462.jpg as you can see , Why I removed four tiny screws. they didn't align together. (for '05 to '10 Odyssey)
IMG_1464.jpg A look from the inside, a snap into place!!a
IMG_1466.jpg Here the 2.4ghz Transmitter secure in place. The we all done~!!! let do some backup testing.....
Discussion Starter #37
Part 3 - Multi-GPS-Backup monitor Rearview Mirror
IMG_1463.jpg Overhead view....I made it fit to '12 Odyssey.
IMG_1372.jpg Here snapping back together. Three screws holding it inside.
IMG_1460.jpg Side-view installed.
IMG_1459.jpg Upclose, with LED light ON...
IMG_1382.jpg Here showing DON'T pass the Yellow lines in the GPS Mirror (auto switch in when Reverse, about 2 sec. delay)
IMG_1383.jpg Real scale
IMG_1384.jpg upclose real scale, less than 2 inch apart from another car.
Total install time: less than 2hrs
Level: Easy to Medium
Discussion Starter #38
Applying Optimum Opti-Coat 2.0 Permanent Paint Coating
Applying Optimum Opti-Coat 2.0 Permanent Paint Clear Coating.......
IMG_1301.jpg Package arrived simple three items.
IMG_1319.jpg Brought a clay kit just ensure the paint free of bugs , micro rocks, oil, ect. Since the van was sit about 18 days in dealer lot.
IMG_1320.jpg tear a piece from the 160g clay and form a round piece.
IMG_1322.jpg Pre-wash & cleaned.
IMG_1329.jpg Started the top then lower side.....
IMG_1331.jpg as you can see, there something in the paint, but naked eyes can't see......
IMG_1332.jpg All-done with clay, it was pretty dirty......then moved the van in the garage (less wind)
IMG_1326.jpg Now getting ready for Opti-Coat 2.0.......see Part 2
Discussion Starter #39
Part 2 - Applying Optimum Opti-Coat 2.0 Permanent Paint Coating
IMG_1333.jpg Did front bumper first.
IMG_1334.jpg side-view of Opti-Coat
IMG_1335.jpg Before.....
IMG_1336.jpg After Opti-Coat
IMG_1340.jpg Before.....
IMG_1344.jpg After......
IMG_1342.jpg Before.....
IMG_1348.jpg After......
Total time just the front: 1-1/2 hrs, maybe whole van will be 3 to 4hrs.
Level: Medium
Discussion Starter #40
will resume applying Opti-Coat 2.0 to the whole van later this week..........
