41 - 60 of 542 Posts
Hi Nomorenow,
I am inspired by your work on LX. I have to start working on my LX van. Just ordered,
OEM: Splash guards, body side molding, cargo tray
Non-OEM: floor liners, chrome pillar posts
all from ebay.
I have to buy the internal lights, HID kit and backup camera recommended by you.
Thanks
Hi nomorenow, Which seat covers are good, I see there are side air bags on the driver and passenger in the front row. which one are better?
Discussion Starter #43
I took some pics for u to see how really looks in the Odyssey. I brought @ amazon $26.95 three colors to choose. Amazon.com: sideless seat cover: Automotive Overall, it's fit pretty well for Sideless seat covers.
IMG_1491.jpg Sideview.......
IMG_1492.jpg Overview......
IMG_1493.jpg Frontview.....
IMG_1494.jpg Backview......
IMG_1495.jpg Upclose........
Discussion Starter #44
Clear Bra Paint Protection Installation
Here is the Installation for the Clear bra kit.
IMG_1302.jpg The mega kit came in two tubes, a good 4 pounds.
IMG_1403.jpg Already applied Opti-Coat (has cured, 4days), Wash & Clean, now ready to install the hood piece.
IMG_1407.jpg Taking out from vinyl backing sheet.
IMG_1408.jpg Layout on the hood for placement.
IMG_1410.jpg Here is with clear bra solution (95% water , 5% baby shampoo home made)
IMG_1411.jpg Align the Bra.
IMG_1412.jpg Align the Bra, Upclose you can see "A" groove for centering.
IMG_1413.jpg Found the center spot & ready to seal it down.
IMG_1414.jpg Here is the tools I used. Hairdryer to soften the vinyl for contours areas.
IMG_1415.jpg Here is installed Hood piece.
Discussion Starter #45
Part 2 - Clear Bra Paint Protection Installation
Here is Part 2........
IMG_1416.jpg Upclose hood Bra installed.
IMG_1418.jpg Now the Headlamp turn.
IMG_1419.jpg Spray with 5% baby shampoo.
IMG_1420.jpg Slide into place.
IMG_1423.jpg Squeeze out water with micro cloth.
IMG_1424.jpg Here it is installed upclose.
IMG_1428.jpg Upclose a angle shot, you see the Bra.
Discussion Starter #46 (Edited)
Part 3 - Clear Bra Paint Protection Installation
Part 3 Final of the Clear Bra Installation.......
IMG_1429.jpg Now will install the Bumper piece, same thing take it out from vinyl backing sheet. ""And keep-on spaying the 5% baby solution"""
IMG_1430.jpg It's pretty long Bra, you'll need extra hand with this piece, and align it together & center it with the "V" groove .
IMG_1432.jpg Center the "V" groove (the "V" is in center of the bra, just fyi) Work one side at a time & use the hairdryer for contour areas.
IMG_1435.jpg Almost done on one-side with hairdryer ""And keep-on spaying the 5% baby solution"""
IMG_1437.jpg Left is done, now ready to do the right-side with same steps.
IMG_1438.jpg All done with Bumper piece.
IMG_1439.jpg Now the Lower bumper (2 pcs, a Left and a Right) Same steps as above. ""And keep-on spaying the 5% baby solution"""
IMG_1440.jpg Again with hairdryer to work on contours. ""And keep-on spaying the 5% baby solution"""
IMG_1441.jpg Cut the excesses piece that is sticking out.
IMG_1444.jpg Final all installed, Hood, Headlamps, Bumper, and Lower bumpers.
Total time: 3 hrs & 20 mins
Level: Medium to Hard (due to the contour areas , Re-align about 5 times & trimming are necessary)
Cost: $60
Final note: Next day, I noticed the Clear Bra is harden prevent blowing off the easy??? (tested in the Freeway for 90mins), it seem really stay in place once installed. Overall I really it , and hardly notice the Clear Bra is installed from walking by the van. Remember for this installation "patience is the key".
Discussion Starter #47
Add Chrome strip to Door handles
I think this one of the last add-on the van, beside the chrome fender trim & the Alloy rims (I'm looking for some OEM Honda's & Acura's in local Craigslist) but not hurry to get it.
IMG_1299.jpg Ordered (Ebay) 4X packs of 15mm wide and 2Meter long (6.5ft) 26ft total. Should be enough for Door Handles & Wheel Fenders.
IMG_1443.jpg Here is before but After Opti-Coat.
IMG_1447.jpg Cut & Trim one side first, Hairdryer was used to install the curve angle.
IMG_1448.jpg One Door handle is complete.
IMG_1456.jpg Both is done, after Cut & Trim **Hairdryer was used to install the curve angle.** and used masking tape hold it overnight.
IMG_1450.jpg Final with masking tape removed.
IMG_1449.jpg another view.
IMG_1497.jpg Overhead view.
IMG_1496.jpg straight view.
Total time: 35mins
Level: Easy
Cost: $14.76 Ebay
Overall: By adding some chrome pieces to the door it does look better. I think EX-L and above only comes with Chrome handles, but I could be wrong.
But hey by doing this I saves a ton $$.
Discussion Starter #48
PreCut Window Tint for Honda Odyssey Sunstrip
I forgot I have just few more add-on came & coming.......so this week is the Windshield Sunstrip.
IMG_1501.jpg I forgot what did I ordered........
IMG_1502.jpg Hmmm....is the Windshield tint strip.
IMG_1504.jpg As you can see is pre-cut so installation hopefully is easy.
IMG_1507.jpg Here a shot b4 the tint installation.
IMG_1508.jpg 1st remove the screw that hold the mirror.
IMG_1510.jpg A cleaned windshield, with the hands clean & ready to go!
IMG_1512.jpg a spray window tint solution (95% water & 5% baby shampoo), and also spray your hands too, so no fingerprints.
IMG_1513.jpg Here unrolling to the windshield, make sure don't drop it the floor, otherwise alot dust. I have my windows all up. No flying dust.
IMG_1514.jpg Finished unroll & over the mirror hump.
Discussion Starter #49
Part 2 - PreCut Window Tint for Honda Odyssey Sunstrip
con't..............
IMG_1515.jpg Making a cut out around the hump.
IMG_1516.jpg Once align, I start off in the center and work the way out, one side at a time.
IMG_1518.jpg Here 95% done, 5% left to squeeze out water. Otherwise will form bubbles in hot days.
IMG_1522.jpg All done! and do final cleaning with foam glass cleaner.
IMG_1519.jpg Pretty much align with pre-cut.
IMG_1523.jpg Angle view.
IMG_1521.jpg Outside view.
IMG_1505.jpg Here is before......
IMG_1520.jpg And here After windshield tint installed.
Total time: 35mins
Level: easy
Cost: $6.49 Ebay - 35% tint
Overall: Once I installed, I noticed right away less glare in eyes without using the visor, since the Odyssey windows is huge,
compare to my Accord.
Another Note: I called local CHP, He said as long no wider than 4inch and is top 4inch should be no problem. He can't promise base on other local police.
Here I found:
WINDSHIELD:
The law allows you to tint the top four inches of your windshield, according to Tintcenter.com. This is known as a visor, and according to California's Department of Motor Vehicles (DMV), it's legal if it meets the following conditions: it's transparent and nonreflective; it isn't red or amber-colored; and its lettering isn't opaque and doesn't obstruct vision. No other tinting is allowed on the windshield.
Restricted Colors
No windows on your car may be tinted "red, amber or blue.
don't forget the rims too...
Discussion Starter #51
Discussion Starter #53
Thanks for viewing~!!!
Like I said, I'm NOT an installer (I wish), I just like to save money, time & help others that could be done with add-on's (DIY).
Great thread. Thanks for sharing
Hi,
Where did you find the DDM HID kit 5k (55w) for $53? I see it $100 on all sites.
I am found Clear View for $50, Kensun for $70.
But the reviews are good on DDM.
Thanks
Discussion Starter #55 (Edited)
hody2012,
here you go... http://www.google.com/url?sa=t&rct=j&q=ddm tuning&source=web&cd=1&ved=0CDUQFjAA&url=http://www.ddmtuning.com/Products/DDM-HID-Kit-Slim-Ballast-35W-or-55W&ei=OSRPT-6wGMaXtwe23qizDQ&usg=AFQjCNF9Zt32ie38MlSSI7BJi2OQrNewWg or google it "ddm tuning"
is $40 + plus shipping $13 <---same shipping if order two set and don't have same bulb/kit.
I did ordered two set for my two cars to save shipping. DDM does about two weeks to get it.
Good Luck~!
Hi,
Thanks
Discussion Starter #57
great job making your Ody your own.... Where did you find the LEDs for the interior and lic plate?
dizzyman,
The LED's:
The front Map light & trunk they are 31mm Festoon 5050 SMD w/ 12 leds, you need three (3)
The interior , Doors , & Lic plate use........
194, 168, 501, T10 <<<---all the same, just different #'s) 5050 SMD w/4 Led's (blue or White colors), Don't get the 5-SMD's led(too long).
I ordered thru Ebay since is the lowest cost, and not in the rush to get it. (it takes about two weeks).
Discussion Starter #58
AVS Hood Deflector & WeatherTech Side Window Deflectors (4pcs)
This week is AVS Hood Deflector (25237) & WeatherTech Side Window Deflectors (4pcs), Let's get started~!
IMG_1626.jpg Both package arrived, AVS Hood Bugflector II (25237) & WeatherTech Side Window Deflectors 4pcs (82556)
IMG_1631.jpg Package contents.....4pcs plastic screws, 4pcs Clear tabs, & manual.
IMG_1630.jpg Remove four 1-way mini clips (mine all four broken).
IMG_1634.jpg Shown here mini clips removed.
IMG_1635.jpg Shown here Bugflector inserted (between rubber seal & the hood) & replace the screw-in type pastic (4pcs).
IMG_1627.jpg Before...... IMG_1637.jpg After......
IMG_1629.jpg Before...... IMG_1638.jpg After......
IMG_1671.jpg Another view, I'm done!................Now let do the Weatherteach!
Discussion Starter #60
Part 2 - WeatherTech Side Window Deflectors (4pcs)
part two.....WeatherTech Side Window Deflectors (4pcs) #82556
IMG_1640.jpg Before....... IMG_1641.jpg After.......
IMG_1644.jpg Another view.......
IMG_1673.jpg Closeup Rear piece getting install. Remember when rollup for the 1st time , MUST rollup 5X slowly!!!!!!! (per manual) and set for 12hrs or overnight.
IMG_1675.jpg Closeup Front piece installed.
IMG_1672.jpg Both installed.
IMG_1676.jpg From the back view.
IMG_1639.jpg Before.......!
IMG_1645.jpg After........! And all completed.......
Total time: 42 mins with the hood Deflector.
Level: Easy
Cost: $53. AVS Hood Deflector (Ebay) & $90.20 (coupon 5%off "mailing5") WeatherTech Side Window Deflectors 4pcs (KBcarstuff.com)
Overall: Must take your time to install side windows deflectors during the roll-ups. That's 5X slowly (like pressing window switch 2-clicks per second).
After that is done, now is the time is enjoy the ride.
