I agree. It did not happen on older cars because the intake manifolds are made from cast iron or much thicker cast aluminum. If I would give a guess, someone may have been troubleshooting a fuel problem and used starting fluid to see if it would fire up. I have done it because it is convenient. But, too much and with a burnt valve, this is what you get. You have to be careful with starter fluid, my brother-in-law set his catalytic converter on fire one real cold winter.And this usually does not happen for no reason. When it happens it's usually caused by a timing system failure. So you need far more than just a new manifold.
Sadly that’s exactly what happened. Tried to get it starting up again. N well that’s the results.I agree. It did not happen on older cars because the intake manifolds are made from cast iron or much thicker cast aluminum. If I would give a guess, someone may have been troubleshooting a fuel problem and used starting fluid to see if it would fire up. I have done it because it is convenient. But, too much and with a burnt valve, this is what you get. You have to be careful with starter fluid, my brother-in-law set his catalytic converter on fire one real cold winter.
Thank you. I will look up.Try your local salvage yards. Also car-part.com
JB Weld works great on magnesium alloy, but now you have the opp. to replace it with a J37 Acura I/M, with assoc. P2R racing gaskets. Have some fun with it, maybe!
