1 - 20 of 40 Posts
http://img412.imageshack.us/img412/5750/img2124v.jpg
I need to make custom mount for the AT transmission as this one is different from 95-97 mount (may be even 98)
I tought that my OBD is OBD2B as there where no TCM :)
Wrong it is OBD2A with TCM build-in.. aka PCM.
Now this is completly diferent wiring from my AT.
So I decide to leave the H23A wires and rewire them to my ody :)
thats the same tranny off the 97+ prelude its set up same as the 98 accords and the 98 odyssey .. if u had that year you could just drop in . but have to rewire the speed sensor .... for the mount get one from a 98 odyssey and you should be fine
Discussion Starter #4
I checked in the honda store and 98 ODY mount seams exactly like 95-97.
You sure 98 will fit?? Anyone have picture of 98 trans. mount??
And I'll keep all as it is. will not redo dizzy or transmission.
Will make it work with 97 as it is.
Discussion Starter #7
Here I'm using the orignal wireharness with the original ECU.
And here the engine is fitting.
This is a great thread! Keep up the work and all the postings.
Any updates? Our 96 is getting tired and we are looking at a Mazda 5 or updating our 96. I found a Blue top with auto here, if a straight forward ordeal, then may go that route.
Discussion Starter #15
Ok,
I was very busy this days with other stuff.
However today the engine started :)
But have some work to finish it.
Will post.
And I'm looking to buy ASAP wire from the Select lever (transmission) of 1998 ODY (NOt from 1995-1997)!!!
congratulations! that sounded similar to some American muscle initially, the sound will all tighten up once you have the exhaust parts mated up. Wow. keep posting your updates and more videos please.
1 - 20 of 40 Posts
