Have a strange issue with our 2006 Ody EXL with 89k miles. Live in TX and the in the past month we have had an odd thing happen with the van a total of 3 times.
The symptoms are as follows:
Check engine light comes on
Notice a rougher than normal idle
Any acceleration causes severe sputtering (can barely get up to 30-40mph)
- giving much gas at all appears to invoke some sort of cuttoff of the fuel. IE: Flooring the car does nothing, but lightly giving a little gas will cause a slow sputtered acceleration.
After Each time it has occurred, turning the van off and then starting again caused the issue to completely go away. Wasn't able to pull any engine codes since the light went away before I could get the code.
The first time it occurred thought maybe it was some bad gas or something since it went away. But it just occurred again after about a month without issue so unlikely that was the issue.
Anyone have any thoughts as to what might cause this? I checked the TSB's but didn't see anything that seemed to match this issue. Guessing it is something with the computer or sensor going haywire for some reason because the issue will completely disappear when all other conditions are the same except that the car was shutdown and restarted.
Thanks for any help!
