1 - 2 of 2 Posts
I have an 03 Odyssey, and I am trying to replace the 2nd row seat belt on the driver's side. The seat belt has fully retracted, and I am unable to get it back out. Does anyone have any tips for getting it to release?
You might want to contact your local Honda dealership.
I believe that Honda has a lifetime warranty on seat belts - they "will repair or replace any seat belt component that fails to function properly during normal use".
Anyway, if you haven't already done so I'd check your warranty info and give them a call. If it's just something simple to get it unstuck they will likely help you with that, and if the seat belt is deemed to be at all broken or defective (or just questionable) they should replace it - free of charge (unless something has changed since the last time I checked warranty info...).
Good luck.
1 - 2 of 2 Posts
