Don't have a picture but on the '02 Ody, it's a black plastic piece located on the bottom of the throttle body. It's the dumbest location ever to put an IAC valve. You have to remove the air intake duct, remove coolant hoses, and remove the throttle cables to get the throttle body off. It should be the same on an '00 model. Once you take the air intake duct off, you will be able to see it better. I had a surging problem and replacing this fixed it.
