Bought my 2019 odyssey two weeks ago. At about 200 miles my breaks started to squeak. It’s a high pitched squeal when I apply the break to stop. Sounds like a school bus breaking. Brought it to the delearship was told everything looked ok and it was safe to drive. They applied anti-squeal and also lightly filed my rear right pad. Still squeaks! Honda told the dealership I haven’t even broken in the car yet and I need to wait until 1,000 miles until they investigate further. I told them it could be my break pads to just switch them out. They said it may not fix the problem. I’m pissed because they aren’t doing anything right now and they could at least be looking at options to eliminate as the problem. Any one else having this issue or had it? If so what was the fix? I’m thinking it could be the rotors too.
I've worked at a Honda dealership before and this is usually due to the cars sitting. The moisture and rain creates a later of rust on the rotors. It may take some time or a few hard brakes to get rid of it. It could even be something else but, the car is so new their can't be any damage. Another thing I thought about was glazing. This will happen when the pad gets heated up on the rotor and pretty much bakes the resin on the rotors. The stuff they put on the pads really just helps with noise when braking. I think you should try and figure it out yourself. Take a metal wire brush attachment for a drill and try to scuff of the rotors and the pad surface. See if this will help. Make sure to do it on both sides of the rotor. People at dealerships can't diagnosis anything or try to help customers because they can't problem solve. They want you in quick and out quick and on to the next.
Sent from my Pixel 2 XL using Tapatalk
Since day one in my Odyssey I can hear a low squeal when I rear up the van. I have reported the difficulty to several workings who have worked on the van. They tell me the brakes are fine; they don't know why the van squeal. Any ideas on why this happens?
Discussion Starter #5
The replaced my pads, machined my rotors and told me one of the clips was bent so they bent it back into shape. Squeaking seemed to be gone. Fast forward about 500 miles later and it’s squeaking again. There has got to be something wrong beyond what they are looking at. Perhaps something wrong with the tire or break assembly which is causing the noise and clips to bend. It’s going back again this week and I don’t even have more than 1,500 miles on it.
