I just swapped out the brakes and rotors on my 2003 Odyssey - Raybestos Pro Grade pads and Wagner rotors. The job went well but now the front driver's side wheel squeals when I turn left and the front passenger wheel squeals when I turn right! It sounds like the dust shield but the sound only happens when I turn. Help! :nothappy:
Thanks
Thanks William, I pulled the wheels and pushed the dust shield back a little. I also looked down along the caliper and could see that one of the clips was sticking out beyond the caliper itself. I pulled the caliper, pad and clip - trimmed the clip with tin snips and bent a piece of the clip to make it tighter when reinstalled. I lubed the clip, installed it, bolted caliper and wheel on and it is quiet!
Thanks for your input! I should have checked the clip clearance from the start but got lulled into a false sense of security by how easy the job was going.
