Hi gang,
I just bought my wife a 2007 odyssey that looks to have been well taken care of with 75,000 miles.What are some of the problem areas shoud I be looking out for and what type of pm should be done at this stage of the vans life?All I here about is transmission problems and timing belt change intervials and cost.Some say 60,000 others say 105,000 whats the scoup?
Discussion Starter · #2 ·
I`m going to change all the fluids and they all look pretty good but the power steering works fine and doesn`t whine or anything but the fluid is dark and has a burnt smell to it how much fliud does this system hold?I just planed on drain fill drive and repeat this three times with 36 oz of new fluid does sound ok or is there another method?
timing belt is at 105k miles (the maintenance minder will tell you), for the power steering, Honda actually recommends having the pump push the fluid out, then refilling the system. Most of the transmission issues are for the previous generation van. If the van is new-to-you, I'd change all the fluids (oil, power steering, brake fluid, and transmission) and filters (air, oil, cabin). Plugs aren't due until the timing belt is changed, effectively (they are iridium tipped - ours actually looked pretty decent when I changed them at 105k miles). Make sure the struts are in decent shape, and check the engine mounts (if it's a model with VCM, the front seems to go early and is expensive - for the others, the side and front seem to go - we had both fail on our van - since we don't have VCM, they are inexpensive, and not a big deal to replace.)
