anyone notice the 2011 has a 1 inch larger diameter tire ? This should give a smoother ride to the 05 - 10 models and the engine /trans is the same . The only problem would be re-adjusting the speedo / odometer so that isn't off. I have a 09 touring so theoretically could use a 235/65/17 instead of the 60 series and much better load rating tire ( nokian WRG2 = 107v ) . Anyone with an idea on adjusting for the different diameter. Also I would like the extra 1/2 inch ground clearance
