Lisa, sorry to hear of your chips. What I would recommend, is that you get a bottle of touch up paint from your dealer (also see H&A Acc.). Also a bottle of clearcoat finish (any good auto store). Use a little bit of dishwasher detergent and a small toothbtrush and rub the area gently to strip away any polisher sealants. Nest use alcohol on a soft rag to strip away any trace of grease or contaminants. Wipe off and let the area dry completely. Using the touch up paint, apply a thin coating the affected areas. Use multiple very thin coats, spacing application between coats so that each coat is dry before applying the next. Build up the area until flush with the factory paint. After this final coat is dry, follow the directions on the clearcoat for application. Let it all dry completely. Important do not apply any polish until a month or so, to give the paint a chance to cure. Then polish the area with a good sealer.
Second important suggestion, buy yourself either a bra for the nose or a deflector, or you will need many bottles of touch up paint. Good luck, hope this helps.
