1 - 2 of 2 Posts
I went with regular run of the mill ngk 2fr5f-11, one of the old ones did not want to come out but luckily a soak of some wd-40 for 20 minutes worked it's magic.
Van runs great, except for a slight knocking ( it has since I got the van at 143,000) that's mostly prevalent for the first ten minutes but I can always here it a little bit (when idling). Doesn't sound like valves. I've used my stethoscope but I can't pin point it. Hopefully it's not the crank!
Andy
Look at your accessories and idler pulleys. Usually the bearings will go bad over time and cause a knocking sound.
1 - 2 of 2 Posts
