i noticed that my dad's 4 rear ceiling vents are not blowing any air in his 01 EX odyssey. i set the front control to RR and try to control the air flow with the second row temperature gauge but no air. even when i use the controls up front for the rear still no air. vents are open. any thoughts?
Rear ceiling vents only blow ait on cooling, not on heat. Rear floor vents blow air on heat and not on cooling. Are you getting air when set to cooling?
Administrator
Not sure about the 2nd gen but that's how its supposed to be in the 3rd gen. I found this out the hard way too with my 2007. Apparently, heat rises so only the floor vents blow hot air. Makes plenty of logical sense. :)
yupe you guys are right. the cool air does come out of the ceiling vents and the hot air blows underneath. thanks
Good thing I am reading the forum and not posting the same problem twice. I never thought to check the lower vs upper vents and see what is coming out from... To my defense, just bought an 02 EX-L.
