2016 touring, 60k. Remote not working, get into car with key, no light. push the button no crank, little green led on the side of button flashes. Push start with key knob starts the car, drive normal except no power door, fcw ldw not working light on. Battery ok 12,5 v, both key battery replaced. Any suggestions? Wire problem? Car parked outside after drive in the noon.
Both key batteries got replaced.
The fuse 16 (backup) in the passenger side under the hood keeps blowing up. This fuse covers a lot of low power equipment including keyless module, FCW/LDW, sliding door controlling module etc. How to isolate the problem?
Just a hunch, but check the corrugated plastic wire covers on the sliding doors for damage. We have also had parasitic draws caused by motors & pull in latches in the sliding door. There have also been issues with the unit that controls the whole keyless unlocking/starting system. Enough times that there may be a bad batch of those units out there. (often back ordered at the dealers)
The truth is, with modern electronic vehicles, avoiding the dealer may not be possible.
Thanks for the tip Egads,
I sourced it to backup fuse 16 in under hood passenger side fuse box. it got a short and keeps blowing. The backup fuse 16 is rated 10A but controls many small load functions like Keyless, FCW/LDW, Home link, door/lock/mirror control module, etc.
Appreciate who can provide some procedures to isolate the problem.
