we added an after market hitch and recently pulled a uhaul to bring home college student. now our brake lights do not work. top light on hatch work when brakes applied. replaced bulbs but still not working. Tail lights work when lights are on. Any ideas?
I suspect your trailer wiring harness is the culprit. Is it still attached to the van?
Check Fuse 47 20a in under hood fuse box. Check F9 in drivers fuse box.If blown the trailer probably had a short. How was the wiring harness hooked up? did you use a coupler designed for the Ody or did someone splice it in?
