1 - 2 of 2 Posts
97, 266K, sitting in the driveway for almost a month, half a tank of gas, obvious dead battery. Charged the battery, put some fuel injector cleaner, changed the plugs, plug wires, forgot the firing order. The engine turns over, don't know how to check for spark. Don't know how to check for fuel injection other than a strong smell in the hose that runs from the airbox to the throttle body. Weekend mechanic, where to start?
The firing order? change the rotor and cap? Check for spark? I can hear the fuel pump whine on ignition click over. Please, please help....I drove the car a couple of months ago across country after a timing belt/ water pump exchange.
I know this is something very simple, so I hear these cars can be pretty reliable. Please, please help, thanks in advance.
Was the only problem when you started the fact you went to change plugs and forgot the firing order? Have you tried doing google search or search here on honda V6 firing order? I did a 5 sec search and found this:
3.0 L V6 is 1-4-2-5-3-6
1 - 2 of 2 Posts
