Has anyone had a front end shimmy after:
New Tires, new or inspected.for.wear front end?
I have. I narrowed down the problem and solution!
Please reply is this becomes valuable to you.
I am a do.it.yourselfer. so I replaced, with a shop press the four control arm bushings. Cost $40. No more shimmy. Pass this on.
If you are not a do.it.yourselfer and you feel a shimmy, do the following like I did:
Check rim trueness and replace.
Balance tires, making sure they do not have bad belts, etc.
Check/replace shocks, tie rod ends, ball joints, sway links, stabilizer bar busings.
Drive it. Is it better? Have you removed layers of problems you never new you had? Finally, if there is a shimmy in the front end, have the mechanic buy and replace your control arms, which each come with two new control arm busings, and a new ball joint.
The above works. I am happy to pass this solution on in hopes that someone will really benefit.
PianoTek
PianoTek
