Have Ody 01, have problem with sticky gas pedal. I need
to confirm what is the correct placement of the cable
especially the cable part under the hood.
the part with nut near rubber tubing.
1. should the nut be clipped?
2. or only the rubber tube be clipped? leaving the nut
outside the clip (that is tracing along the adjusting nut).
my ody 01, current throttle cable placement is no.2.
I just wonder if placement of the cable has something to
do with sticky gas pedal.
i am isolating cable first, before I will check the TB itself.
