- Hi all
- I Was accidentlly short 1 hot wire to the ground now my van won't start, crank but not turn over , the green key icon in the dashboard keep blinking, No DVD or Navigation on ( can change CDs in the CDs changer), both side doors, power tailgate won't open either , power windows still work, all the lights still work, i tried 3 diff key but no luck
- replace immobilizer unit will fix this problem? or any fuse, relay?
- Any helps will be appreciate it
- Thank You
Honda_Dude
Check all the fuses. You may have blown several of them.
- Thanks Will
- Fuse #13 under-hood Fuse Box blown , now can start, both side doors, power tailgate works but still no DVD and navigation, i will keep checking other fuses
