hi i bought 2 weeks ago Honda odyssey 2001 macanic found tensioner problem there i changed that after 2 days 2 bolt of alternator is broke macanic gona put both but i want to know is that save for future or it could be happen again thanks :huh:
Bonjour and welcome to the site!
It is advised that when a timing belt service is done to replace the tensioner at the same time as these will fail eventually and cost $ in labour to fix. Also at the same time, the water pump, and the 2 pulleys should be replaced as well.
The tensioner failed and probably put stress on the alternator bolts.
thanks for answer but may be i did not explain my problem properly i try again my van tensioner was loss that way he changed that but after 2 days alternator bolts was broken the put new bolts but my question is that is that secure for future or it could be happen again what i do thanks
The bottom alternator mounting bolt should be torqued to 33 lbf·ft and the alternator bracket mounting bolt should be torqued to 16 lbf·ft.
