1 - 10 of 10 Posts
Hello guys.If some one can advise me please.I didnt find it so far anywhere clearly.How can i get HDMI on on EX 2019?
Thank you so much in advance.
I know that EX-L model does have HDMI built in already
I want to get it install on my EX, i was wondering if it's possible
EX-L does not have HDMI unless you get the RES. Seeing as it’s not an option on the EX.....my original question is still valid. What would the HDMI in an EX connect to? There is nothing there.....
Discussion Starter #5
I want to have HDMI so i can connect my phone to Head Unit, mirrow it. It's actually better than AndroidAuto. Using Amazon Fire Stick which goes into HDMI you can connect the phone.
It can’t be done. I suspected that’s what you were trying to do. It can’t be done even if you had the RES, which you don’t. There is no way to do what you want to do UNLESS you root/jailbreak your phone. Then it could be done via either Android Auto, or Apple CarPlay.
Discussion Starter #7
Really? I know about rooting. But i dont think it can be done via Android Auto. Do you know how?
Thank you
Thank you
As I mentioned, it can 100% be done via Android Auto. I myself use it on my Rooted OnePlus 7 Pro with my 2018 which is identical to your 2019. Google AAMirror and go from there. As always, XDA is the best resource for all things Android.
Discussion Starter #9
Thank you very much
Will check it out
1 - 10 of 10 Posts
