1 - 2 of 2 Posts
2000 Odyssey: driver's side power door will not shut when pulling handle. It does open/close with FOB. The door will open by pulling handle. I tried the fuse #13 trick with no success. I need help, what's the next step?
Once again, to close when you pull the handle it has a rod that makes a switch in the lower rear of the door frame. The switch could be bad, the door rollers missing causing the door to be out of alignment, etc. Anyway you will have to look at the door and frame to find what is happening. The trim will have to be removed to get the switch and the inner door panel will have to be removed to check the handle/rod mechanics.
1 - 2 of 2 Posts
