Whats good ppl, like the title says, need a big help from you all off set gurus, got my self a S2000 OEM rims, 16x7.5 rear/ 225-50-16 and 16x6.5 front 205-55-16. seeing that one of the member already did this on his RA1, kinda convince me it will be just plug & play, but the PROBLEM is the rear is rubbing on the lower arm, tried to pm the member partsman_01, but no avail, should buying a wheel spacer will do the trick??? or just changing the rear tires to 205 will solve this problem, really would love to rock the S2K rims, it looks really sleek on our ride, thanks in advance for any input.
Check a tire maker's site to see the dimensions of the different tire sizes.
I would be wary of adding a spacer. This would put a lot of stress on the studs and also on the outer wheel bearing.
