Hi,
Our 2006 Odyssey has the following info at the oil status screen on dash:
B Change Oil
3 -307 (flashing)
The last oil change was barely 2K miles ago. The car has about 66K miles.
Any insight into the cryptic message would be greatly appreciated. Thanks!
Super Moderator
tcoreander said:
Hi,
B Change Oil
3 -307 (flashing)
It sounds like the oil life monitor, as part of the maintenance minder system, was not reset after the oil change.
B service is an oil and filter change and inspections.
3 service is to replace the transmission fluid
-307 (flashing) means your services are overdue by 307 miles and should be done ASAP.
Please refer to your owner's manual, as it explains all of this info in full detail.
I simply ignore the reminder and maintain the car using "old-fashion" methods such as:
- Engine Oil every 5-6K
- Flush ATF every 20-25K
- Change Engine Air Filter every 20K etc etc.
The schedule for maintenance for most cars are very similar.
