Replaced the spark plugs in my '05 EX-L (w/120k mi) and two plug hole coils had oil on them. Both of the respective coils had seals at the top that had popped out. I can't get the seals to stay back in and wonder if that is what is causing the oil to pool on the spark plugs. All spark plug tips and threads were clean of oil so it's obviously coming from "above". I've search this forum but can't seem to find any past experience with this issue. Otherwise, the van has no apparent misfire or ignition issues.
Should I just replace the coils (just to get new seals) or is there another issue that I'm missing?
Thank you!
Brandon
Thank you!
Brandon
