Thanks to this forum, I was able to fix my sons 96 oddyssey.It sprung the leak on him and I was like what the Hell.My other son towed me me home so I could look at it.Very easy fix...$ 3.07 for o-ring (91316-PE7-730)from Honda dealer,$9.82 for 30mm socket from checkers,autozone only had up to 29mm,$ 25 for oil and filter,and bam it was fix.I jacked car up,put it on stands,and went under from front of car,to me it was the easy way.You dont have to undo the 2 hoses on can,I cleaned can,then I used ky jelly on o-ring to keep it in place on the can and then reattached can. I put 2 quarts in car an let it run for a minute to make sure it didn't leak and then put the oter 2 quarts in..fixed...
If you need the can it was $ 346.00 ouch
what you need:
jack
jack stands
30mm socket
o-ring
4 quarts of oil
filter
what you need:
jack
jack stands
30mm socket
o-ring
4 quarts of oil
filter
