Hey all, I have a 2004 Odyssey and have recently developed an oil leak. I traced it to a tube that is right below (actually bolted to) the radiator. There is a hose coming from the drivers side, clamped to this tube that has a hole, then another hose clamped to the tube going to the passenger side. The tube is maybe 12"-16" if I can remember correctly, and it has two brackets possibly welded to it which are used to hold it to the radiator. Oh, and the leak is coming right from where one of these brackets are attached to the tube. Big question is, does anyone know what this line is for, and where I can get one? Looks to be an easy fix if I can find one. Thank you!
I tried posting the actual link to it but it goes back to the home page. After entering your information select Electrical/exhaust/heater/fuel. In that list select radiator hose. I think what you want is item 11 at $36.44
