Guys I have a very small leak. It appears it is coming from the top back of the engine and drips down to the Oil plug. It drips maybe a dime sized drop once a week. It's more annoying than anything, but wondering if this is common or a seal needs replacement.
I took my 2008 in yesterday for a small oil leak that leaves the entire oil pan area and a section of the frame on the passenger side wet but not enough to drip on the floor. I only began to notice it after the last few oil changes. Each time I wipe down all the area so I know it's still occurring. I was getting to the end of my power-train warranty so I thought I'd get it checked out. I only have 20K on the clock but it's an '08. The tech said it was coming from the washer on the oil drain plug. I've never changed it but it looks fine and is tight. So, I bought 6 new washers and will change it out every oil change as the tech said they do at Honda. I hope this does the trick.
The oil pan drain plug has a 'crush' washer that needs to be changed with EACH oil change.
