I have a 1999 with 72,000 miles on it. It is regularly maintained and is in good shape.
Today when I moved the car from the garage, I noticed 3 drops of oil on the garage floor.
It is all the way upfront, about 2 or 3 feet from the very front, middle of the car.
I know oil could travel before dropping but what might be the best guess of where this leak is coming from?
Thanks.
Could be as minor as a loose drain plug, or as major as a leaking rear crank seal. An inspection is needed to track it down.
There are lots of places the oil could be coming from. I've had leaks from the rear main seal, oil pan, oil pan drain plug, and the final one that just got fixed the oil pump.:nothappy: You'll need to get under it and look to see where it is coming from or put it on a lift and look.
