Hey all, was poking around my 2009 ex-l the other day and found a small sweating oil leak on the passenger side, coming from under the motor mount, above crank pulley. Can anyone advise on what is leaking? What to replace?
You can try that but I doubt that it will work or last. When you buy a new hose be sure to get a genuine Honda part. This is also a good time to flush the power steering fluid and install the new and improved reservoir.Looks like it was the hose into the power steering pump. Thanks all! Gonna try to get one of the screw hose clamps and secure it on.
Something I have a learned from @John Clark, I had an issue like that....not as a big, but the screw holding the bottom hose (low pressure) was wet on steering wheel fluid. I thought it was the clamps holding the hose, per @John Clark recommendation was to replace the low pressure hose and leave the clamps alone. I ended up replacing the hose and keeping my old oem clamps and so far dry as a bone.Looks like it was the hose into the power steering pump. Thanks all! Gonna try to get one of the screw hose clamps and secure it on.
New and improved reservoir? Aftermarket part?You can try that but I doubt that it will work or last. When you buy a new hose be sure to get a genuine Honda part. This is also a good time to flush the power steering fluid and install the new and improved reservoir.
Correct. If the new hose doesn't come with the clamps you can reuse. The issue is not the clamp. It's the old and dried out hose.Reuse that spring clamp. Much better than those screw band clamps in this application.
