I have noticed recently a coating of oil appearing on some items under the throttle body and intake manifold. Unfortunately I couldn't get my head in close enough to see the problem. I finally stuck my camera down in there and got a pretty clear picture of the area. The second picture shows a splatter area only on one side of the yellow plastic connector, therfore this leak is blowing out as opposed to any drip. My question is, can anyone identify the most likely problem area based solely on the attached pictures. It doesn't seem to be a major leak (if it is even definitely motor oil) as my levels are fine when checked and it doesn't leak onto the ground. This is a 2005 EX-L w/~120k.
