Hello,
First I'd like to say this is a great forum , helped me out so much on my 95 Ody. @ 197 K miles.
I'm doing the timing / balancer belts , water pump , seals , etc.
I noticed some oil on the rear of the engine block ,looks like from around the oil pan gasket and oil cooler O ring , replaced the oil cooler O ring , but getting grey hair trying to figure out how to remove the oil pan....
removed the exhaust piece , cross brace , but hangs up on the Torque Converter Cover plate. Everything I've read says to just drop the pan straight down , ....
I removed the three bolt holding the torque converrter cover plate ,but it has a flange that slides in place and can't get it out ....
Thanks for any advice ........... John H.
